All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #31
Old 19-11-2008, 08:50 AM
saj0n1 saj0n1 is offline
Registered User
saj0n1 is on a distinguished road
Ok, finally got it done last night after formating my laptop to XP.
Not noticed alot of difference so far, may seem a little quicker and still no function for the navi wheel?
Also has anyone else noticed that all 3 of the default themes are the same???
I've updated via pheonix, as soon as NSU update comes out I will reinstall with that just to make sure there are no further improvments.
  #32
Old 19-11-2008, 09:20 AM
N73Me_2007's Avatar
N73Me_2007 N73Me_2007 is offline
Registered User
N73Me_2007 is on a distinguished road
any new when this will become available on nsu, still say no updates available
__________________
Mobile Phone HISTORY:
  • 2001 - 3310
  • 2003 - 8310
  • 2004 - 6610
  • 2005 - 6230
  • 2006 - 6230i
  • 2007 - N73
  • 2008 - N96 -cURRENT
  #33
Old 19-11-2008, 09:54 AM
ant_coe_ ant_coe_ is offline
Registered User
ant_coe_ is on a distinguished road
Hello!
Got the files myself, thats phoniex 2004 with the 2006 patch and the firmware for the n96.
before i go in alone, i would also like to have a step by step if thats okay
if you could send it me that would be nice.
Thanks in advance
EDIT: managed to get the files to eventually work, (i used phoneix 2008 with the files floating around on the net) updated perfectly, and tomtom is miles quicker (sorry about the pun). either hold off and wait for it with nsu or get the update and risk bricking. There is defiantly a small speed increase with the update, but its not in any way drastically different.
Tony
Last edited by ant_coe_; 19-11-2008 at 04:57 PM. Reason: Reason? - I dont have to explain myself to you!
  #34
Old 19-11-2008, 05:47 PM
Registered User
Well a bit dissapointed really, now on V12 not really noticing any difference........in fact the delay in loading screens for message replying or forwarding is worse! takes a little longer to load up, display comes on then its about another 10-15 seconds until signal and battery power icons come up?
Did it right format-upgrade-format, just not impressed not the revolutionary firmware update I hoped it would be.
Oh yeah stil no navi wheel
  #35
Old 19-11-2008, 07:33 PM
Biggzy's Avatar
Biggzy Biggzy is offline
Registered User
Biggzy is on a distinguished road
did mine also via phoenix bout an hour ago, id been told by 3 people that there was more free RAM at bootup (63mb), mines still around 50mb free, phone is faster etc with no lags tho.
__________________
www.SymbianScientist.com
It's not technology, it's what you do with it.
  #36
Old 24-11-2008, 03:09 PM
funkychunky87 funkychunky87 is offline
Registered User
funkychunky87 is on a distinguished road
Firmware Flash Instructions...
Hey,
I tried to follow quite a few guides with poor results, then I came across this one below and it sort of worked, then I found out the issue I was having was due to one of the installs being the newer version, so I tracked down the older version, installed, it picked up the drivers and installed them (it was having issues with the ROM driver). I've put all the software I used at mtlinternational.co.uk/nokia. I had to do a few clean installs of XP for this to work, you MUST install to your C drive for this to work.
"1st of all Before Flashing:
- Make sure your phone is fully charged
- backup your phone settings !!!!!
- remove the memory card and the sim card from the phone!
- remove all Nokia drivers or Nokia software from your pc YES including Nokia pc suite
- make sure you delete all the empty ' Nokia directories' from C:\Program Files\
(rebooting might be a good idea here)
Install those files in that particular order :
1_ Install msxml6_x86.msi
2_ Install vcredist_x86.exe
3_ Install Nokia_Connectivity_Cable_Driver.msi
4_ Install Nokia_Flashing_Cable_Driver.msi
5_ Install Nokia_Service_Tool_Drivers.msi
6_ Install FLS-4Drv1.34.exe ( click next next next and say yes when prompted )
7_ Install Phoenix_Service_Software.msi (Version 2008)
8_ Fix Dongle by installing Phoenix_2006_2008_fixer.exe
Then you install firmware (Nokia_firmware_RM-247_EMEA_12.035_v04.00EFAJQROM.exe )
to C:\Program Files\Nokia\Phoenix very important you install this to the phoenix directory
** please note that I installed everything in its default location witch is why my path is C:\Program Files\...
Now ,
In order not to get screwed up always format your cell before and after flashing firmware. Use this code to format *#7370# default security code needed is 12345, if you changed it use your own code.
Step 1 : _ Start Phoenix
Create User if it asks to. ( it did not ask me maybe it will ask you who knows ! )
Turn on the phone (it will start in offline mode because there is no SIM card inside).
Plug in the USB cable to both the phone and the computer.
When prompted, select "PC Suite" from the menu list on the phone.
Wait for *all* drivers to fully install themselves before proceeding.
(If some driver fail to install unplug phone, reboot pc / start phoenix then connect phone it should work )
go to 'File/Manage Connection/
click on 'new' then check the box that says USB , click next ,It will then search your USB ports for the phone. When it finds it, click Finish , click apply then close
go to 'File/scan product then change the operating mode to Normal
go to 'Flashing/Firmware Update then browse for your product code
( I am in North America and I chose Europe 1 everything worked perfect I have an Unlocked N96-1 with chinese and english keypad)
Hit 'Refurbish'
You will get a message saying : An optional file is missing. This file is: RM247_001_000_M007.fpsx. Would you like to continue flashing? Just hit YES"
  #37
Old 25-11-2008, 03:01 PM
CraigBruce CraigBruce is offline
Registered User
CraigBruce is on a distinguished road
Grrr - hurry up NSU! Before I go ahead and flash it myself anyway.
The v12 firmware is my last hope - if useability of my N96 doesn't significantly improve following the firmware upgrade, it's ebay for this puppy and back to my N95 (or even purchase of a non-Symbian/Windoze phone). I've consistently been an early adopter of Nokia Symbian handsets and seen poor performance with early firmware before, but the N96 has driven me to search the net frantically for a senior Nokia email address to complain to. Can barely stand the slow refresh when opening or replying to text messages!
Please Nokia - get v12 on NSU soon....it wont necessarily save my N96 from ebay, but it's giving it a chance!
  #38
Old 25-11-2008, 08:52 PM
goaten2000 goaten2000 is offline
Registered User
goaten2000 is on a distinguished road
Too late for me. I've had the N96 for best part of a month now and it's unbearably slow - even the N95 wasn't this bad when it was first released !!
  #39
Old 26-11-2008, 09:15 AM
Biggzy's Avatar
Registered User
those of you with slow phones need to format phone mem and the mass memory, alot of ppl have same problems and after a full/hard format everything works fine
__________________
  #40
Old 29-11-2008, 09:19 PM
adray-m adray-m is offline
Registered User
adray-m is on a distinguished road
I am having bother trying to flash my n96. I tried it normal flash and dead flash and all i get is "Unable to set the phone to flash mode. Unable to flash." after it runs through all the normal sending stuff...
Could someone help me with this please.
Old 03-12-2008, 03:28 PM
craz69 craz69 is offline
Registered User
craz69 is on a distinguished road
Quote:
Errrm, does anyone still have these files??
  #42
Old 04-12-2008, 03:31 PM
Stezo2k Stezo2k is offline
Registered User
Stezo2k is on a distinguished road
try ipmart, no links though
__________________
Phone History: 5110, 3210, 3510i, N-Gage, 6670, N70, N95, N96, N97
  #43
Old 08-12-2008, 06:53 PM
Flip95's Avatar
Flip95 Flip95 is offline
Registered User
Flip95 is on a distinguished road
12.035 or 12.043?
The rapidshare phoenix file was for f/w 12.035
NSS now reports that 12.043 is available .... very interesting!
  #44
Old 08-12-2008, 07:12 PM
Registered User
Yeah, I never really got any sort of improvement from v12.035, and with nokia never releasing it left wandering it if was genuine?
Upgrading to 12.043 now via NSU, so will see how that goes
  #45
Old 22-12-2008, 09:26 AM
VSG12777 VSG12777 is offline
Registered User
VSG12777 is on a distinguished road
Smile My N96 Updated to F/W 12.043
Hi everyone
Just wanted to post here regarding my 1st couple of hours with the new firmware.
* Mode of Update: Firmware Over the Air, using WLAN thru my home wireless broadband connection
* Size: Around 2.5 to 3 MB
* Time taken: In total, around 10-12 mins (including downloading, restarting etc)
* Custom version: 12.043.098.1
* Firmware date: 26 Nov 2008
My observations:
* Phone is generally faster to use. Menus seem to open up faster.
* SMS reply screen comes up faster in my phone. New SMS screen also faster.
* The scratchy beep sound (especially when changing profiles) is gone. Beep sound is now smooth.
* Free phone memory is 40.2 MB, while free space in mass memory is only 5.1 GB since I have lots of songs and some videos stored. Memory details were checked from inside the Music Library.
* Operation of phone is faster even with more complex themes, like those made by the creator "Dhanusaud". Ivanov's themes like Saku and Spirit are also installed and the N96 is now faster with these themes as well.
* Navi wheel still not enabled. Only "breathing" option available.
The update was done last night around 8pm or so. These are my initial observations. Shall post back later with additional observations if any.
Thanks and warm regards,
Venkat
(Chennai, Tamil Nadu, India)
Ads
Bookmarks
Tags
firmware, n96, update, v12x
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Update firmware of N70? reeza Nokia N70, N72 and N90 2 14-05-2008 06:54 AM
Firmware update mjdj1689 Nokia N95 and N95 8GB 1 06-07-2007 01:25 PM
How to update firmware? menhel Nokia N71, Nokia N73 and Nokia N75 8 03-01-2007 07:21 AM
Can't access settings after firmware update tissier Nokia N71, Nokia N73 and Nokia N75 1 02-12-2006 09:37 AM
A "Feedback" from Nokia H.K. on firmware update!! manman Nokia 7650 4 26-09-2002 10:46 PM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
