All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #31
Old 22-07-2009, 05:47 PM
davecozens's Avatar
davecozens davecozens is offline
Registered User
davecozens is on a distinguished road
Quote:
Originally Posted by nbriscoeuk View Post
Great work Dave.
Quote:
Originally Posted by Gerco View Post
Starting the phone in English shows a dd/mm/yyyy date representation and in Dutch dd-mm-yyyy. A '/' versus a '-'.
Hmmm... Presumably the javascript engine isn't properly localised but the API is... Maybe if I replace the / with - first it might cope...
New version if you fancy having a look. I'm assuming the date parser was failing...
D
__________________
Dave
NEW: Tweet & Share GPS location: Locator
Fed up of Adware on Ovi? See my Freeware, Wallpaper and Accessories sites...
FREE News Widgets for Symbian, UK Traffic, News, Football, Movies and Gadgets/Tech.
More at www.davecozens.com/
  #32
Old 22-07-2009, 08:55 PM
Gerco Gerco is offline
Registered User
Gerco is on a distinguished road
I definitely fancy!!! I really appreciate your effort and when it works, I will definitely use it, as I really miss something that shows my next appointments on the home screen! So keep up the good work!
However, I downloaded again, reinstalled, but unfortunately the result is still the same. It works fine when the phone is switched to English, but shows very old items with the NaN indications when switched to Dutch...
  #33
Old 22-07-2009, 09:00 PM
jamessmith01 jamessmith01 is offline
Registered User
jamessmith01 is on a distinguished road
Reinstalled - still a blank screen on main screen, and the widget is no longer in the 'add content' menu on my homescreen!
  #34
Old 23-07-2009, 06:48 AM
davecozens's Avatar
Registered User
This is crazy... The least reliable api ever! *sigh*
Well, I'm stumped. Sometimes I get a black widget for about 30 seconds, but it eventually loads.
Sometimes it loads instantly. And it doesn't load at all for you!
How long are you waiting for it? What happens if you load the main app?
__________________
Dave
  #35
Old 23-07-2009, 07:52 AM
Delveh Delveh is offline
Registered User
Delveh is on a distinguished road
Hi Dave,
First of all great concept for a widget! It Does help me!
Not to add to your problems but.....i've got a small one.
Within my calendar i have a Memo on 01/08/09 and meeting on 15/08/09 and 20/08/2009 however the widget is picking them up as 01/07/09, 15/07/09 and 20/07/09 - Note the 07.
But it does pick up the next meeting on 15/08/2009. So its as if the Widget has gone 1 month behind?
Not sure. Just thought i'd feedback.
Thanks for it though! Makes life easier!
Delveh
  #36
Old 23-07-2009, 08:48 AM
davecozens's Avatar
Registered User
My bad. I always forget that in JavaScript land january is month 0. Should be fixed now. Same URL...
D
__________________
Dave
  #37
Old 23-07-2009, 12:22 PM
Registered User
Just downloaded the revamped one. Its now showing All Anniversaries right back to the year they initially started. I.E Girlfriends Birthday is showing right back till the year she was born.
So now its now working :(
Ads
  #38
Old 23-07-2009, 12:31 PM
davecozens's Avatar
Registered User
oops. my bad. left the debug setting on (which shows all appointments)...
gimme a sec...
__________________
Dave
  #39
Old 23-07-2009, 12:36 PM
davecozens's Avatar
Registered User
ok. should only show future stuff now. sorry :(
__________________
Dave
  #40
Old 23-07-2009, 08:12 PM
Mike.mp Mike.mp is offline
Registered User
Mike.mp is on a distinguished road
Works fine for me Thx mate!
Give me a tip where can i learn something about creating a widgets!
__________________
N97
Software version: V 11.0.021
Software version date: 15-06-2009
RM-505
Language set: 11
  #41
Old 24-07-2009, 06:57 AM
davecozens's Avatar
Registered User
There's Nokias intro page http://www.forum.nokia.com/Technolog...s/Web_Runtime/
The WRT wiki http://wiki.forum.nokia.com/index.ph...time_%28WRT%29
And the full documentation is here http://library.forum.nokia.com/topic...4B2CFF109.html
A good working knowledge of javascript will help too... Good luck!
__________________
Dave
  #42
Old 24-07-2009, 08:52 AM
Registered User
Works fine! Thanks for info on creating!
  #43
Old 24-07-2009, 09:04 AM
Registered User
Trying to uninstall the widget, but I get 'file corrupted'. The widget is not present in the 'installed applications' list in the application manager. Hmm?
Edit: fixed after a restart. Will try and reinstall.
  #44
Old 24-07-2009, 09:21 AM
Registered User
Uninstalled the widget.
Restarted phone.
Installed the widget.
Restarted phone.
Loaded the main program - white screen as before, with "open calendar" in the corner.
Added the widget to homescreen - showed "loading content" for a few seconds, now just a completely white box.
Is it possible the previous installations left behind some files or settings that are corrupting the current installation, or is it just buggy for some reason on my phone?
  #45
Old 24-07-2009, 10:19 AM
davecozens's Avatar
Registered User
After the wild compatability differences from different instances of the same handset I can only come to the conclusion the the widget API is flaky at best.
I'm having trouble with contacts on another widget I'm working on. Apparently some contacts will cause the whole widget to crash. No way of knowing which they are though. Nightmare.
I may very well give up altogether!
__________________
Dave
Bookmarks
Tags
calendar, homescreen, widget
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
S60 Widget development made simple Richard_Bloor Series 60 0 30-04-2009 10:44 PM
Huge problem with the calendar on Nokia 9300i - can not copy it to E90! Lordbaer Nokia E90 0 15-11-2007 08:55 AM
6680 Default Wallpaper on the Orange Homescreen jpsanders Nokia 6630, 6680, 6681 and 6682 5 19-07-2005 12:40 AM
Outlook Sync - Major Calendar Problems sasben Motorola A920, A925, A1000, Benq P30 and P31 and Arima U300 1 07-12-2004 09:42 PM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
