All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #31
Old 29-01-2007, 04:48 PM
chapelhill chapelhill is offline
Registered User
chapelhill is on a distinguished road
mailforexchange and SBS server
I have been having problems with this too and have managed at last to get it working with an SBS server. Here follows what I hope is the sequence that I used, but be aware that you try so many adjustments, there may be extra or less steps isnvolved.
I followed all the instructions on the net and was successful in installing the cert, but the prompt messages kept appearing.
We are using SBS server premium.
I saw this web page which refered to certsrv directory which did not exist on my server.
"www .msexchange .org /tutorials/SSL_Enabling_OWA_2003.html" (Remove spaces)
The default installation of my server did not have the windows component certification services installed, however the sbs certification wizard worked ok for pc's, so I followed the instructions on the web page, (note warning about name changes) right to the end. I checked from an external pc that the certificate was working.
Then using my home pc I browsed to "mail .mydomain .com/certsrv" (Remove spaces)
and logged in as administrator.
Select request a certificate
Select user certificate
Then select submit (With xp pro and explorer7 it says no futher details required at this stage, you may get different options.)
Click ok to warning about scripting
Screen then comes back saying certificate was issued and a link to install the certificate and click yes to the prompts.
This then installed two certificates to my pc.
Tools>Internet options>Content>Certificates
There were two certificates installed a personal certificate and a root trusted certificate, I browsed to the root trusted certificate and exported in der format, converted .cer file to .der file using openssl as per web instructions, copied resultant file to root of server, modified mime types for .der files on server as per wen instructions, browsed to the file using native explorer in E61 which then gave me option to install which I did and voila it worked, only took me 3 days!
Note the previous certificates I managed to install always had the local host name as the properties, whereas the final one use the correct fqdn used for webmail.
From what this exercise has taught me there are 3 bits to certification, Authority, server and client. The client gets the client cert form the server and then warns if it cannot get to verify against certifying authority. The bit we need to install is the certifying authority to get rid of the prompt. Without the full cert services in the sbs there is some limitation which prevents us getting a correctly formatted certify authority, thankyou microsoft!
Thanks to all the other posters, and good luck to anyone attempting their own configuration.
Regards
Chapelhill
  #32
Old 08-02-2007, 01:59 PM
jazztronic jazztronic is offline
Registered User
jazztronic is on a distinguished road
Problem installing auto-signed certificate
Here's my certificate (in owa.zip) at DER format as described in this forum.
Unfortunatly, none of the solutions worked in my case.
Can someone help with this ?
File Type: zip owa.zip (557 Bytes, 363 views)
  #33
Old 07-03-2007, 04:52 PM
Nostra Systems Nostra Systems is offline
Registered User
Nostra Systems is on a distinguished road
Important Info
Hi Guys
Read this piece especially the second part dealing with cert imports
nostrasystems.ie/smartphone.php
Regards
Senan
  #34
Old 23-03-2007, 01:10 PM
pauleec pauleec is offline
Registered User
pauleec is on a distinguished road
Beer the E61 is ruining my life!
well, not quite that bad but I am losiing the will to live. I am attempting to synchronise my E61 with a Exchange 2003 SP2 server using Roadsync. I have managed to import all the required certificates (bought one from Go Daddy) onto the device, the settings are correct, I have setup RPC over HTTPS on the server and that works. But still the bloody thing won't synchronise.
The Roadsync error I get suggests that my account has expired (no), my username is greater then 20 characters (no) or my password or username is wrong (no again - have tested with other users, etc). I am completely flummoxed. If anyone has any ideas please let me know. Many thanks to sunlie and Senan by the way, their posts on here helped me with the certificate issues in a big way. Great forum (shame about the E61).
Paul
Ads
  #35
Old 22-09-2009, 11:13 AM
dan_the_man dan_the_man is offline
Registered User
dan_the_man is on a distinguished road
Is this thread still open, need help
Hi
Is this thread still open, i need help on this issue with openssl.
How do you use it with the command line, i have downloaded "openssl-0.9.8k.tar.tar" and extracted it to a folder put the cer file in there but get "not reconised as an internal or external command"
Do i have to install it somehow first?
Hope someone is still reading this and can help.
Thanks...
  #36
Old 18-11-2009, 12:51 PM
thomasstuart thomasstuart is offline
Registered User
thomasstuart is on a distinguished road
Hi Guys I am Thomas.
I also have the same problem. Make sure the certificate is in the DER format, not base64. The Exchange server can export the format for you by going to http://exchangeserveraddress/certsrv/. Copy the cert to your phone with bluetooth or whatever and then open it. It will ask you if you want to install it. After, you won't be prompted.
__________________
pda accessories
Bookmarks
Tags
certificate, e61, import, server
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
MAIL: N70 / TLS (IMAP/SMTP) W/Self Signed Certificate -hicks- Nokia N70, N72 and N90 0 05-04-2006 08:10 PM
Nokia Licence MS Exchange Server Active Sync Technologies Ewan Symbian OS News 0 14-02-2005 08:38 AM
Image-Uploader works with my own Server! Try it for yourself projektil Nokia 7650 25 03-12-2002 10:30 AM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
