All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
Go Back   All About Symbian Forums > News and Comments > Series 60
Thread Tools Display Modes
  #46
Old 21-04-2009, 07:44 AM
Unregistered
Guest
Posts: n/a
Unhappy Download issues
Hi guys im having the same problem with downloads as the other guy. Every application downloaded is showing an expired certificate message.
is there any way off sorting this out without deleting my certificates or lowering my security.
PLEASE HELP, im not getting the best out of this amazing phone.
  #47
Old 27-04-2009, 04:36 PM
JGJones
Guest
Posts: n/a
Accuweather
I thought I'll point out that in Download! in the widget section, next to Accuweather is Weatherbug - I have to say I found this much better than Accuweather in that it respond much faster and a more slick interface. It also get GPS, radar and so on like Accuweather - so we get two decent weather app And weatherbug is also free - I went with Weatherbug first because in Download! it stated "Try for free" for Accuweather which implied shareware to me, whereas Weatherbug was "Free" so I tried Weatherbug first...and I like it a lot.
Ads
  #48
Old 29-04-2009, 06:42 AM
Unregistered
Guest
Posts: n/a
Quickoffice for Nokia 5800XM
Is it possible to download Quick Office for Nokia 5800XM on the PC & then to install on my handset?
Regards,
vkjain315@gmail.com
  #49
Old 03-05-2009, 10:43 AM
dsbs
Guest
Posts: n/a
u change ur phone date to earlier time like january , restart the phone then install. After installing change date to normal. One application i am suggesting is Symtorrent it is good to download full movies and other large files. I am using 5800 in india from 2nd january and it is good phone. Soft version is now 21 after 2mb ota download.
  #50
Old 05-05-2009, 03:07 PM
Unregistered
Guest
Posts: n/a
Comprehensive list of free apps
Here is another big list of free applications for the 5800 - http://anarchius.org/v5projects-Noki...plications.htm.
  #51
Old 06-05-2009, 08:17 AM
Ecophil
Guest
Posts: n/a
Thumbs up Screensnap is available for S60 5th
http://www.smartphoneware.com/screen...on-product.php
  #52
Old 01-07-2009, 10:24 AM
Unregistered
Guest
Posts: n/a
problem
certificate expired what to do man
  #53
Old 04-07-2009, 02:20 PM
Unregistered
Guest
Posts: n/a
Accuweather
Hi, i've looked in Download! and I have no widgets section! I also don't have Web as its been replaced by T-Mobile's Web'n'Walk service, no bother as i use Opera anyway. but is the Widgets section something else that T-mobile might remove?!
  #54
Old 06-07-2009, 02:32 PM
Unregistered
Guest
Posts: n/a
Unhappy download problem
  #55
Old 15-07-2009, 04:21 PM
mkj011 mkj011 is offline
Registered User
mkj011 is on a distinguished road
freeware trouble?
Hello steve
thanks a lot for this list you have made. I loved the accu weather application.
However have run into trouble with two ( they r minor though).
PHONE TORCH
After I had installed this , I had done a full back up of phone using Nokia Content Copier where for the first time I had ticked all to be backup (i.,e including MEMORY CARD contents) , it had initially frozen at 67% ,then I had cancelled and
got a successful back of about 1Gig safely.
After these two events when I connect my Phone, and choose mass storage mode to use it like any external hard disk am having the following nuisance:
I click open on any folder say IMAGES
The main window of EXTERNAL DRIVE F closes and restarts again as if i just plugged in the phone as external hard disk.
This repeats N number of times, however I could use Nokia PC suite's file
FILE MANAGER to successfully use the phone as external disk.
Also as I was using FILE MANAGER i suddenly noticed the PHONE TORCH
shortcut on my homescreen has been replaced by NOKIA MAPS!!!
And when i restarted the phone, Voila it was back on home screen!
The reason am mentioning the bug is, am not sure if PHONE TORCH caused it or the initial update of entire phone contents caused it.
I have uninstalled phone torch ,and no difference in the bug as mentioned above. And I didn't feel like installing it back, because of the disappearance of
phone torch icon from the home screen automatically.
Now abt Open office
I had installed it. But its not there . When i checked it on installation manager
its not there.. Then i tried to install again ( DOWNLOADED caption was already being shown on the DOWNLOAD! application list beside the open office ) .Now when i tried second time, got warnings of FILE CORRUPT and
failed installation.
Otherwise, gmail, google maps, all went fine. and thks for the list again.
mkj
  #56
Old 17-08-2009, 06:46 AM
Unregistered
Guest
Posts: n/a
access internet thru wifi
something problem when my phone (nokia 5800 EM) connected to wifi, i cannot connect to internet, even google site..the displayed was 'web authentication' i need help for this..?thanks
  #57
Old 20-08-2009, 03:51 PM
Unregistered
Guest
Posts: n/a
Smile :) Hi
tnx!!!
  #58
Old 02-09-2009, 09:54 PM
Unregistered
Guest
Posts: n/a
you forgot vyke !
  #59
Old 12-09-2009, 03:50 PM
Jayanta_05
Guest
Posts: n/a
Need help installing AccuWeather
Hi- I've downloaded the AccuWeather app on my Nokia 5800 but when I'm trying to install it its giving an error message saying "Unable to install-Error occured" and "Installation failed". If anyone has faced this issue plz help! -Thanks!
  #60
Old 16-09-2009, 06:51 PM
Unregistered
Guest
Posts: n/a
Nokia is cheating this time(Nokia5800)-
1. picture quality is like old VGA camera (I was using N73, which has same specification but picture quality of nokia 5800 is worst).
2. Nokia says it as a music phone but music quality is same as old phones (ya, its headset jack is a good thing)
3. No adobe reader in 5800....i have to buy it for Rs. 800.
4.some times it goes off automatically.
5. now i m facing prolem, it does not boot....On switching on phone , it shows nokia logo but does not start....i have shown it to customer care twice but now again same prolem.
6. No file hide software....initially they proides u, file hide software which is a demo n like many other software they demand money after trial period.
7. Games devloped for it r pathetic.......if u like mobile games, this phone will make u cry. this phone is not compatile for most software or games u download from net.
8. its real player plays nothing... u have to download smart movie player software for playing movies which expires after trial and demands money, otherwise phone shows yor movie file as currepted file, even if it is in right formet.
Bookmarks
Tags
5800, 5th, edition, freeware, nokia, s60, xpressmusic
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Nokia extends IBM Lotus email access to S60 slitchfield Series 60 7 19-11-2009 12:17 PM
The 5800 and S60 5th Edition get 'Zinged' slitchfield Series 60 1 13-02-2009 12:38 PM
More Nokia 5800 XpressMusic tutorial goodness slitchfield Series 60 4 12-02-2009 09:05 AM
Epocware's stable hits S60 5th Edition slitchfield Links of Interest 5 27-12-2008 03:25 PM
Some neat S60 5th Edition Nokia freebies slitchfield Series 60 7 14-12-2008 08:46 AM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
