Hi guys,
I recently bought a NOKIA 3230 , tried to install some symbian apps and got screwed up big time . Right now all I see is a white screen . (Is this similar to the windows blue screen of death ?? 😊 ) . Could you guys help me out with this ? Im hoping a full format would help . How can I do a full format on 3230 ?
Thanks in Advance,
Neha
On doing some research in this forum I found these for 7710 and 6600
7710 -- *#7370# ( punch in the code after the welcome screen)
6600 --
Here to let everybody how to perform a
Full phone formatting on a 6600!
If you encounter situation like below on your 6600,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Unable to delete unwanted files on C drive.
Do a Full phone formatting on your 6600! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6600 phone.
4. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
5. After a few minutes when the Full phone formatting completed, your 6600 will back to original system and factory settting.
how can i format nokia 3230? please answer me! thank you.😡
KEKI_E wrote:how can i format nokia 3230? please answer me! thank you.😡
You have the answer above your post. Are you blind?:hmmmm:
i did this on my 3230...but since i had some problems with it it died during the format...can somebody tell me if i can fix it without going to nokia service center????thanx
buy a battery only charger not the phone charger.
how can you backup a contact if the phone is down?
