IP Passthrough tutorial - use your PC Internet connection from your phone
36 replies · 89,129 views · Started 21 July 2006
If you've just received your new e-series phone, you'll probably want to try out all those cool connected application such as the nokia web browser, email client, worldmate, widsets, google maps or Internet radio. But unless you're lucky enough to have an unlimited data plan or a wifi access, using those applications is going to cost you a fortune in GPRS or 3G charges. Luckily, Nokia provides an application that allows you to use your PC internet connection from your phone connected via USB. It's easy enough to set up but since it took a little while for me to realize that that was possible, i suppose that others are not aware of that either. So here is a small tutorial.
I've tried it with my work PC connected to the Internet via my company's ethernet network. It should work just as well with an ethernet or USB broadband modem but i haven't been able to try it since my home PC, which is connected via a USB modem, died just minutes before i was about to try it 😞 (seems like Toshiba laptops don't like just the thought of being used as a mere IP passthrough).
UPDATE: my laptop being back and working again, i've tried to set up IP passthrough on it to try and connect my E61 to the Internet via the USB broadband modem connected to my laptop. I couldn't get it work. The phone won't connect.
1) make sure that you've got Nokia PC suite installed. I actually don't think that you need it for IP passthrough but i haven't tried on a PC that didn't have it installed. You can download the latest version here: http://europe.nokia.com/A4144903
UPDATE: Nokia PC Suite is actually required for IP Passthrough to work. Make sure that you restart your PC at the end of the installation procedure if prompted to.
2) Download and install the Nokia Network Bridge application: http://www.forum.nokia.com/info/sw.nokia.com/id/99ffe0f8-34d3-46c2-a069-ba83b9dfdce3/Nokia_Network_Bridge.html
(there's a pdf file there too that explains how to set it up with a nokia communicator. It's pretty much the same procedure with the Exx)
3) Now you'll need to create the IP Passthrough access point on your phone. On the phone, go to menu -> Tools -> Settings -> Connections -> Access Points. Choose Options -> New Access Point -> Use default settings. In Connection Name, enter a name for this access point. For example, "PC Passthrough". In Data Bearer, choose IP passthrough.
4) Then go to Options -> Avanced Settings. Whenever the phone will be connected in IP passthrough mode, it's going to behave just as if it was connected directly to the newtork so it needs to have an IP address and know the address of the DNS and gateway servers. 3 cases here:
- Case 1: your PC (hence your phone) is connected to the network via DHCP. This is the case for most company networks. In this case, just leave the default settings. Only indicate the address and port of the Proxy server if there is one on your network.
- Case 2: your PC uses a fixed manually assigned IP address. In this case, you'll need to give your phone an IP address too. Go to IPV4 Settings and enter an address in Phone IP Address. Be careful not to choose an address already in use by another computer on the network (and of course, do not use your own PC address). If you don't know what address is still free on your network, ask your network administrator, he should be able to give you one. For the rest of the settings (subnet mask, gateway, DNS), they must be identical to those used by your PC. If you don't know them by heart, under Windows XP go to Start menu -> Control Panel -> Network Connections and double click your network connection (probably called Local Area Connection). Then click Properties, scroll down and select Internet Protocol (TCP/IP) and click Properties. All the settings will be displayed. Enter them on your phone.
- Case 3: you have no idea of what i'm talking about. In this case, you're probably connected via DHCP so don't touch anything and leave the default settings.
5) Click Back and Exit until you're back to the Active Standby screen.
6) Connect your phone to your PC via the USB cable. The phone will ask you what kind of connection you want to make. Choose IP passthrough. It sometimes asks it several times, so choose IP passthrough every time.
7) On the PC, go to Start menu -> Control Panels -> Nokia Network Bridge. You should see your phone listed there. If not, wait a little while for the phone to be recognized by your PC and it should show up. Place a check mark in front of your phone then click OK to close the window.
8) That's it. Nokia PC Suite will tell you that the phone is connected in non-compatible mode but that's normal. On the phone, launch an application that requires an internet connection such as the web browser and when it asks for the access point to use, choose the one you've just created. The phone will then connect through your PC Internet connection.
9) When you're done browsing, simply disconnect the cable. The next time you'll want to use your PC internet connection, just plug the phone and choose "IP Passthrough", nothing else to do.
IP passtrough... Oh boy! My resume, with different phones.
9500 - I have donne like you said, because it has a detailed manual in Nokia Site.
I try and retry, and, or nothing happens, or 9500 made a reboot. Never had been able to connect.😡
3230 - with Gnubox project. http://gnubox.dnsalias.org/gnubox/. I donne everything, more than once, and again, no lucky!😡
N-Gage + N-Gage QD + 6600 - total sucess, with that: http://www.russellbeattie.com/notebook/1001649.html:icon14:
I can do all I want, with the internet conection on PC!
What�s the difference between them - Bluetooth SPP - Serial Port Protocol, wich the last 3 have, and 3230 don�t, and 9500... i don�t now. I think not, but in Specifications said Yes...:con?
Wirelessly posted (Mozilla/4.0 (compatible; MSIE 6.0; Symbian OS; Series 60/0610.04.04; 7439) Opera 8.60 [en])
i must have been lucky then or maybe the implementation of ip passthrough has been improved in the e61. Between the tjme when i knew nothing about ip passthrough and had never heard about it in my life and the time when i was happily surfing on my e61 using my pc internet connection, there was less than 5 minutes. And that includes the time it took to download nokia's software
Hi Folks!
Very nice "How To", but I have problem. In our corporate network is IP adress granted by DNS, but it is only for specific MAC Adress of Network Adapter. Do anybody idea how to do it without asking for registration of another network adapter?
I don't know if that's gonna be possible.
When i was in the university, i had the same problem. We had network access via ethernet in our rooms but had to register the MAC address to be able to connect. I had registered the MAC address of an old PC i had but then got hold of an old Macintosh laptop. In order to get it on the network, i activated Internet Connection Sharing on my Windows 98 machine, connected the Mac to the PC via a crossed ethernet cable (luckily, the PC was an old IBM server and had 2 ethernet adapters) and after loads of tweakings and head banging, i finally managed to get the powerbook on the net. Only to realize that its 4MB of RAM and 25MHz processor was definitely not good enough for surfing even with Netscape 2.
So this kind of things is possible but since your phone doesn't have an ethernet plug, i don't know whether your PC will be able to share its connection with it. You could maybe try to connect it in IP passthrough mode and maybe install the nokia netork bridge app and see if you can configure it via Windows' internet connection sharing panel.
elp wrote:I don't know if that's gonna be possible.
Thanks for advices,
I am going to try make an internet connection sharing, today afternoon... its working between 2 computers, so I hope it wil be work for phone, too...
If not I will thing about buy Wi-fi adapter to my computer and try it with Wi-fi...
nooooooo, nothing of this works for nokia e60 since it is not listed in network bridge window from control panel... ha, can you fix it???😉
misha_scg wrote:nooooooo, nothing of this works for nokia e60 since it is not listed in network bridge window from control panel... ha, can you fix it???😉
If you've followed my tutorial to the letter, then i don't know what's wrong. Are you sure that you chose "IP passthrough" on the phone when you connected it and validated that several times if it did ask you several times? Have you waited long enough after you've connected your phone for your PC to recognize it?
vijayjamesmani wrote:Can i use pc internet on my N80 phone?? do reply
I'll reply if i want to 😎
Does your N80 ask you whether you want to use IP passthrough when you connect it to your PC via the USB cable? If yes, then you can use my tutorial to use your PC internet connection from your phone. If not, then you're out of luck.
I actually has the same problem as you did yesterday. I installed the latest version of Nokia PC Suite but didn't restart my PC at the end as it wanted me to do since i had other things to do. When i tried to connect via IP Passthrough, it didn't work anymore, my E61 wasn't listed in the control panel. I restarted my PC and everything worked fine again.
So PC Suite is required for IP Passthrough to work. The reason is that it installs the necessary drivers for your phone. Without these, your PC won't be able to see your phone when you connect it.
elp wrote:I'll reply if i want to 😎
When i connect USB cable its asking for
PC suite
Data Transfer
PictBridge
these are the 3 options im getting..
i tried installng the nokia network brige software but noting is being detected in the software when i connect my phone.
do help me in browsing the net from my pc on phone..
thanks
vijay
I followed the tutorial but I am unable to use my internet connection on my mobile. when I connect the data cable to cell phone I connect it through
IP Passthrough option and also selected in control panel Nokia Network Bridge appropriate phone. Internet is working fine on my PC but on my mobile I am getting error about "Web: No Gateway Reply". It also shows a network connection for my phone. This LAN connection getting IP Address from DHCP Server. Which DHCP Server I don't know. I am also sending you the pics may be these are helpfull for you.
Pls solve this problem if any one knows about it. My Phone is working fine through my Wireles Router.
Thanx.
Muzammil
Attachments: IP.JPG IP2.JPG IP3.JPG IP4.JPG
chmuzammil wrote:I followed the tutorial but I am unable to use my internet connection on my mobile. when I connect the data cable to cell phone I connect it through
Mmm, based on your screenshots, everything looks fine to me. The IP address, DHCP address and Getaway server address that have been given to your phone appear to be correct.
- This might sound very Windows-like but have you tried to reboot your phone to see if that changed anything?
- Under Windows, go to Start menu -> Run... -> type cmd and press enter -> type ipconfig. Is the gateway address displayed here for your PC the same as the one that has been given to your phone? Does you PC IP address begin with the same 3 numbers as the one given to your phone (the last number must be different)?
- Have you tried to connect on your phone using Opera Mobile (not Opera Mini) instead of the Built-in Web browser? I have found that the built-in browser had all sort of problems when trying to use a newly created connection while Opera works a lot better. Once it's working with Opera, it then also works with the built-in web browser.
- Maybe there is some filtering somewhere on your network based on computer's MAC address, which means that you'd need to register the MAC address of your phone with your network administrator in order to be able to use it. Ask him/her. This is very unlikely though since MAC address filtering usually happens at the DHCP level so if your phone was not allowed to connect, it would not have been allocated an IP address.
Hi All,
I have done everything (install the network bridge, install the latest version of PC Suite, etc..) to connect to the internet on my mobile via my desktop using USB connection. However, in gives an error on my computer saying:
"Nokia9300i (RNDIS) connected in non-compatible mode"
Also I cant see the phone on "Start/Control Panel/Nokia Network Bridge"
Can someone please help me what i have to do to connect to the internet using my phone?
Thanks in advance
ozhan u.
at the beginning i had issues, but a guy helped me, and its really working perfectly! installing nokia network bridge is required only for drivers, cause i do not use it at all in ip passthrough setup and use. first of all, creat an ip passthrough access point on your phone. name it as you wish, for data bearer select ip passthrough and thats all! install nokia network bridge. then connect your phone to your pc via cable, cause thats the only way to have it working. when connecting, select 'ip passthrough' and then let the pc recognize it. it will ask for your drivers, use oem11.inf drivers listed. if it says 'the device cannot start', restart your phone! then you should let your pc aquire the network which will have limited functionality. let it be that way. go to control panel, enter network connection and select create a home or small office network. if there are any disconnected connections listed, ignore it. in next window select directly to the internet option which is the first one. choose next, and then select your pc internet connection. next, select your e series RNDIS connection listed. next, do not turn on file and printer sharing, choose next at it will start connecting. when it gets connected, it will ask for your windows xp cd, do not use it, check the last option which says something about not required on your device bla bla... and that is all!!! try to browse something from your phone, use ip passthrough connection in it, and happy surfing!!!
Am I missing something here? What's the point of surfing the net while tethered to your computer via USB cable?? :con? :con? If I am going to sit so close to my PC, then I might as well surf using the PC, isn't it? It would be useful if this thing works via Wi-Fi..(b'cos in office like mine the Wi-Fi network access is via 3rd party tool viz Odysessy and so I can't connect my E61 to Wi-Fi network in office). Then I can be connected via Wi-Fi to my PC and use my PC's internet connection to browse the net on my e61.....that be so totally COOL 😎 😎 😎 😎
DDGuy wrote:Am I missing something here? What's the point of surfing the net while tethered to your computer via USB cable?? :con? :con? If I am going to sit so close to my PC, then I might as well surf using the PC, isn't it? It would be useful if this thing works via Wi-Fi..(b'cos in office like mine the Wi-Fi network access is via 3rd party tool viz Odysessy and so I can't connect my E61 to Wi-Fi network in office). Then I can be connected via Wi-Fi to my PC and use my PC's internet connection to browse the net on my e61.....that be so totally COOL 😎 😎 😎 😎
Could be by Bluetooth, but is not like Wi-Fi, because the range is limited at 10mt max.
Ok, I was curious to try it anyway but its not working on my E61.
I reached so far as to get the network icon in my laptop tray showing "connected" but on phone no web page can be opened. My office network uses http proxy (Microsoft proxy) for web access and may be that's the reason. First I had set up proxy server IP and port under "advanced setting" for the access point but then I used to get an immediate error on phone when I open a web page "web: Unable to perform operation" and so I removed it (My proxy needs a user name/pass and phone has no place to specify it and so I expected it to fail anyway)
but after removing it , the phone keeps trying to open a web page and times out finally.
The icon in the tray shows speed as 12 MPBS and its properties shows a local IP address and a local gateway address (what is this? phone's IP address??). On the phone side I don't see any active connection under "Act Data Conn." under connectivity menu(??).
What's wrong ?????????
Edit: And one more thing, in Nokia Bridge in Control Panel, I see THREE entries - all for my E61 but one each for Wired LAN, Wi-FI LAN and Blue tooth LAN. Right now I have ticked off only the Wired-LAN one based on the instructions here. But this is confusing me 😞
Futher EDIT: I do have a mcfee desktop firewall but its disabled all the time
nj7 wrote:Could be by Bluetooth, but is not like Wi-Fi, because the range is limited at 10mt max.
Even that's better than a connected USB cable but HOW ???:frown: :frown: :frown:
I said in general... not necessary on E61. For first S60 phones, like N-Gage or 6600 (the last one) they have SPP Bluetooth, so the connection is direct. After that only with Gnubox project for several S60 phones. Check is E61 is supported or not. But, like you said, E61 have Wi-Fi, a lot better way to make the connection then Bluetootth.
Wirelessly posted (Mozilla/5.0 (SymbianOS/9.1; U; en-us) AppleWebKit/413 (KHTML, like Gecko) Safari/413)
Hi elp i've done every thing you sed step by step but
1. A did't see may phone in the network bridg screen
2 the contaction of the pc network was so bad that could not make a internet contaction.
So my q is'
do i need an adsl contaction that fast to make inter... Cont...
thanks
Elp
Hey buddy
i have E61. so i did the Same thing as u wrote
i have installed all the softwares u told here and they r working fine but After Connecting my mobile to my com its making connection Like Local area connection 5 and while Acquiring the ip address it shows problem.
and its cant make the connection with my com So that why i cant make a Access point in my mobile
tell me what i will so
DDGuy wrote:Ok, I was curious to try it anyway but its not working on my E61.
Ok, I have an update-
I could get it to work in my home where there is no proxy server. So some points-
1) Nokia bridge works only when u are having a Cable Ethernet connection. I was connected to my home network on wi-fi and bridge didn't show me anything. So I had to haul my laptop next to router and connect the RJ45 cable to the laptop and then it worked.
2) The solution works only when u don't have any proxy server in your internet access path (that's why it didn't work in my office but worked in home). This suck as office is where I want it to work (in home my E61 can connect via wi-fi anyway. In office wi-fi we have odyssey client based authentication rendering my E61's wifi useless.
Next I need a similar solution but instead of using USB cable, I want to use Blue tooth...I know its possible (URL is there but I am not allowed to post) but I am struggling to get it up on my E61..( I have reached so far as to install GNUBOX in my E61, get the test connection working but Internet access still fails😡 😡 ) Any body has any ideas???
elp wrote:Guys,
...DDGuy reported having problems when internet access was made through a Proxy server. The E61 does not seem to be able to authenticate against a proxy server. But the PC does know how to do that. My guess is that ICS could be a solution here. If ICS is activated and Nokia Network Bridge is configured to connect through this virtual connection, then this might solve the proxy server problem as it's the PC that would take care of authenticating against it while the E61 would be unaware of the proxy server. This is just a wild guess of course but worth trying.
Houston we have a problem !! In my office, my laptop is configured to work in my office domain and now that I am in home and logged in locally (as a local admin) to my laptop, it somehow still knows that it is supposed to work in a domain and as a result the moment I start ICS wizard, it says "can't do it, as u are part of a domain"
