problem with phone memory
4 replies · 2,002 views · Started 02 April 2004
it says i have 3220mb free on phone mem but wen i get sent a video via bluetooth it says memory full. wats the problem and if i need to delete somethin wat do i need 2.
Go to Messages-->Options-->Settings. Then down to the last option (others?*). Then change the used memory to MMC (memorycard).
That should do the trick.
*i dont know what its called in english, i have Dutch language on my phone.
I've had the same problem and to think I have a 128MB MMC, with the setting of using the MMC memory. Ive tried sending a huge file over bluetooth and it said the same error about my memory full or something...
Thing is, just maybe, it buffers the file first over the phones internal memory then copies it to the mmc...
But if the above suggestion worked fine then good.
But as for me I use a card reader instead cause transferring mp3s and videos over bluetooth could be time consuming, battery consuming and tiring... 😉
You're right, card reader is the best option. Sending MP3's over bluetooth can take very long time.
