Home screen reverts to default after crash
3 replies · 6,435 views · Started 05 July 2011
Hi all.
I have a C7, very pleased with it apart from the fact that it occasionally crashes. Some widget (it never says what) causes it to freeze, then reverts all home screens to the original set of home screen backgrounds AND icons/widgets, then I have to pull the battery. About 4 times in 4 months so far.
Apart from trying to figure out which widget it is, is there anything I can do to put my home screens back the way I want them (it takes about 1/2 hour each time).
I will make sure I backup weekly so I can revert (once I am home). Anything else I could do? No magic app that saves your homescreen settings?
thanks
CAB.
Screen 1
1. Clock/profile
2. Contacts widget
3+4+5. Coming Now (calendar widget)
6. Shortcuts
Screen 2
1. SPB Weather
2. Shortcuts
3. Mail for Exchange
4. Shortcuts
5. WLAN
6. Shortcuts (including the AAS app!)
Screen 3
1. Internet Radio
2. Music
3. FM Transmitter
4. Shortcuts
5. Nokia chat widget (usually offline)
6. Shortcuts.
Theme
"Colours" by MMMOOO
At the moment, no background programmes running.
Any advice appreciated.
Go to Menu > Memorycard > Options > Make Backup .
After the Crash : Menu > Memorycard > Options > Restore From Backup .
Only the latest Backup will be restored . So regularly make a Backup .
This might allso include Notes . Notes newer than the Backup will have disappeared .
😊 Regards jApi NL
