N8 HDMI,the pointer problem and double audio Options
4 replies · 5,043 views · Started 21 July 2011
Hi;
I have two questions about my n8;
[SIZE="5"]1. Question:[/SIZE]
While connecting the mouse, I have no problem with the pointer but when my n8 is connected to the TV via HDMI, the mouse pointer disappears.(however, i want to control a video and its volume via the the mouse) How can i get it visible?
[SIZE="5"]2. Question:[/SIZE]
While watching a video that has a dual audio on n8, i want to enable 2nd audio. How can i do this? Is there any software which is appropriate for this job?
Re Q1: I tried this on my N8 and the mouse worked find while connected to TV via HDMI. I was using an Apple Magic Mouse (bluetooth connection).
Re Q2: I'm looking for a short video to download that contains dual audio...
matthewrleech wrote:Re Q1: I tried this on my N8 and the mouse worked find while connected to TV via HDMI. I was using an Apple Magic Mouse (bluetooth connection).
so, you say the mouse problem stems from the device?
it is weird that the pointer works and appears on n8, and it also appears on tv while i am moving among the applications. but it does not appear on tv while i am watching a video.
Sorry, I thought that you said the mouse disappears as soon as you connect to the TV via HDMI. I did not try playing a video.
