Hi All,
First of all please sorry for my english language. I had read all the conclutions wrote in here about new Symbian Devices. I really wanna buy Nokia Device, since i have using nokia phones from 2003. So I don't want go for a any other brand. I'm not refusing those device. Becuase I don't have any of the experience with other brands.
anyway This is my point, I have two models in my mind. But I don't know which one I want to choose. One is Nokia N8 and Second is Nokia X7. I'm get confused becuase of some points.
N8 have 3.5" screen but good camera and within one month time anna update will come to that.
But X7 have 4" screen but have 8MP fixed focus camera with anna.
I'm good music listner(not hardly used) and hard use(calls and sms & camera) of phones. earlier I had use Nokia N95 and Nokia X6.
So If some one can give me a suggestions from these two devices I really appreciate. and I need very quick reply becuase I wanna buy a phone soon.
out of the two phones you listed the nokia n8 will do you better then the x7 and you should be able to find it cheaper then the x7 as well , in the uk the x7 is more exspensive then the n8
buxz777 wrote:out of the two phones you listed the nokia n8 will do you better then the x7 and you should be able to find it cheaper then the x7 as well , in the uk the x7 is more exspensive then the n8
Thank you for your opnion. In Sri Lanka also X7 is expensive than the N8. Perofrmance wise I don't know which one I want to go. So Still I'm getting confused buying which phone... I need more suggestions guys.
in almost every department .. you would be foolish not to buy it if you are only considering the X7 instead.
Anna will be released for N8 soon .. well .. fairly soon .. ok .. sometime .. but the current software is reasonable.
seki wrote:in almost every department .. you would be foolish not to buy it if you are only considering the X7 instead.Anna will be released for N8 soon .. well .. fairly soon .. ok .. sometime .. but the current software is reasonable.
Thanks for your reply seki. I;ll go for the N8 soon and I'll join the N club soon
Camera, Charger, Lock button, Card Slots and FM Transmitter = N8
Everything else = X7
Does the X7 have FM transmitter? If not then get the N8. I have had the same phones you mentioned. I have also played around with both the X7 and the N8. Ask your self do you want a slightly larger screen or a much better camera.
I went for the N8 and LOVE IT!
Wagane wrote:Does the X7 have FM transmitter?
No, it doesn't... a huge lack for me 😞
