Ovi Store will not logon to account after Anna update
1 replies · 10,535 views · Started 19 August 2011
Hi All
Ovi Store app loads Ok but will not log on to account or create new account after Anna Update.
I have all current ovi updates - reinstalled anna a few times - I have reset to factory defaults and undertaken a full hard reset .With the hard reset every thing seems to work OK except OVI logon.
Any ideas ?
Thanks In Advance
Boothy
This worked for me with latest downloaded ovi installer
`I've updated my C7 with symbian Anna and have problem with Ovi Store as well (stuck at loading screen) , but it solved, solution here:
1st, i want you to know that symbian Anna (Firmware 22.014) provides Ovi Store 2.12.042 also contains QT 4.7.301, it seems that the newer version of QT cause Ovi store error, so go in here :http://fixqt.com/ and download QT 4.7.3 files then install them in order and overwrite the newer QT.
i've got my Ovi Store working again by using this method .`
Boothy
