Hi, i kinda lost my wifi password but i have the wifi as known in my phone so is there anyway to check it in a private folder or using an application?I would have used the pc to check it but i cant access it
Help finding wifi password
The phone isn't storing it in any file/location that'd be readable. You need to find it from either the router (if it shows it in clear text), or reset/change it in the router.
