to replace smart connect (birdstep)
3 replies · 6,099 views · Started 30 August 2011
I just changed a E7-00, but found that smartconnect by birdstep is not supported this model.
I found this software super good, to combine all wifi & 3G in one access.
Does anyone know which other app can replace smartconnect suitable for E7-00??
The E7 does it automatically, to a fashion.
You use a "destination", e.g., "Internet", and then list the access points (cellular, Wi-Fi) there, that the phone is allowed to use for "Internet" access, and their priority/order.
Then you configure apps to use "Internet".
Settings > Connectivity > Settings > Destinations
Really really good, I never know this is already inside.
Yes, I set up this internet as access point now.
However, some app, like UC Browser, cannot select this "internet" as access point, what then ???
Go into destinations and find the access point you want to work in UC Browser.....press and hold to reveal the pop up menu....then, Organize, Copy to other destination....and copy it to WAP. Now try connecting in UC Browser and it should work. 😊 If not....while it's displaying a list of connections to use, press and hold any Connection name....and "Select Access Point"....yours will appear in the resulting list (probably twice now, if you copied it across to WAP
