getting anna update without ovi suite
1 replies · 9,115 views · Started 04 September 2011
hey everyone im in toronto canada and bought an unlocked N8, but when i checked ovi suite to update to anna it wont give me the option.
also when i check my phone to get anna update, its says no updates available?
is there any other way i can get the anna update along with the camera update at all?
It should eventually be made available for your Variant.
If you don't want to wait you can flash a firmware of Anna from a different country variant or region. Perhaps some euro1 UK would be a good choice. You can do this under "Product Code Changer" in the newer "Nokia Care Suite" application. However it isn't intended as consumer software (this is the software they use at nokia to refurbish phones etc..) and it voids your warranty.
Worked for me on the C7.
