Has anyone else had problems when running the backup and restore application with the p800?
I've had a few failures halfway through running both backups and restores. In one case I had to reset the phone (and lose all my data) as the restore had left it in an unstable state.
I'm running Windows 2000. Any ideas?
Im running windows XP and the only time I had a problem was when I had APbooster installed. Right now I have an error popping out after back performs, but the error is a phone startup error and doesnt affect my back up (I think)
Thanks. Yeah the problem did first occur when I was restoring after installing AppForge Booster. I had to reset the phone and even then Appforge seems to have left some files on the phone which cannot be deleted using FileManager as they are "in use".
Does anyone know how to remove AppForge completely from the phone?
I uninstalled the appgorge file with 0mb and it uninstalled all the others succesfully 😊 I guess you could just manually delete them using qfilemanager.
