FM Transmitter not in Hong Kong Version
7 replies · 6,989 views · Started 13 October 2011
I exchanged my E7 for the N8 recently as i thought the FM transmitter would be a good gimmick to have. Unfortunately, i found out pretty quickly that the Hong Kong version does not have this function.
Anyway, does anyone know if the hardware is in my phone still, and just the software is preventing me from using it? If so, is there a way to enable it?
malcolmlau wrote:I exchanged my E7 for the N8 recently as i thought the FM transmitter would be a good gimmick to have. Unfortunately, i found out pretty quickly that the Hong Kong version does not have this function.
pick a Singapore code or somewhere similar if you still require the Chinese support
Most probably it, indeed, is disabled for legal/regulatory reasons, in the software for some countries (where using it isn't allowed, or requires some special license, or some such difficulty). It is extremely unlikely that Nokia would bother to make different hardware versions just for disabling the FM transmitter in some countries.
maniani2525 wrote:vI'm looking for a device that allows me to play the songs from my ipod library through my car speakers.
or some similar device .. you really are asking in the wrong place though 😊
Hey I know this is an old topic.
But I find myself in a similar situation whereby my nokia 808 has HK region firmware installed. It is a good firmware as it supports chinese input methods, plus by default there is a shutter sound disable in the preferences. The only issue is there is not FM transmitter.
I have looked up and found that all HK region nokias will have FM transmitter disabled. And I see changing to a Singapore region firmware will re enable the FM transmitter in the operating system, plus chinese input is retained. My only issues with that firmware is that the Camera shutter sound disable feature is not allowed in that region, so I will be stuck with a horrible camera sound everytime I capture an image.
So I am stuck here, either having a Nokia 808 with FM transmitter but shutter sounds permanently enabled or no FM transmitter and shutter sounds ability to be disabled.
Help
MAzor
yes the tranmission range of the n8 is soo little, that unles the phone is right near the car stereo the quality will not be good.
Anyway with modern cars, they have bluetooth, and bluetooth stereo is far superior than fm transmisssion any day.
Also I am in the same boat with my 808 hk edition. I know the hardware fm transmit is there but just cannot be bothered re firmware hacking to a different region, as I enjoy the ability to disable shutter sound by default, and chinese support.
