Hey I've had this problem ever since I opened the cover of my 3650. now there is constantly dust and other crap in the screen. any ideas how to clean it/stop it? i've also scratched the cover i think because in the bottom right corner the screen is sorta 'blurred'.. and there is a air bubble somewhere 'coz i can see something which resembles a dead pixel but it depends on what angle u hold it.
jeff.
hey there, one way to prevent it from the start is to never open the FRONT cover. it can cause many problems like dirt and tht. i knw most ppl will disagree when is say dont mess about wiv covers.... i knw its boring but it will save a lot of hassle i for sure wont really open my front cover unless i really need to
Turn your phone off - when the screen is powered up it will attract dust!
Remove the cover and give the screen and the plastic case screen a wipe with Mr Sheen anti static dust guard on a soft cloth.
IT WORKS 😊
My screen is perfectly dust & smear free 😉
Best
Will
hav u actauly tried tht physicaly ur self then?
Yes - I did it yesterday.
Wow.. I'l try that. But I'm scared of turning him off!! My 3650 must stay on forever!
Really.
I have to reboot mine at least twice a day - else the memory gets fragmented and programs stop running.
Also new SMS's stop comming in untill I reboot once I've run a couple of large programs.
I guess these 1.34 firmwares are not very good at memory managment.
Best 😊
Will
yeh i've had the same problem
screen is full of dust and stuff (you can't really see it with the backlight on tho)
i've tryed different things to get rid of it but as of get nothin has worked
i'll try the above suggestion
