Hii there!!! 😃 😃
I�v got a problem!
My new P800 is superb but i�m really worried about the screen!
Have you guys ever had the problem that you by mistake got the screen scretched?
I cant think of something more annoying that can hapen to me! I dont care about the phone itself but getting the screen damaged would make me angry!!
Have you ever had any problem with this or maybe you know something about it, pleas give me a coment! Thanks 😃
Andreas
Somebebody had his screen replaced, try using the search function 😊 Is yours scratched or cracked?
Sounds to me like nothing happened yet - he�s just worried about it. Right? If so - get a screen protector. (people say that Brando is the best choice) It should work against scratches. I don�t know of any Brando retailers in Sweden (I guess you�re swedish ?), but you can find Brando screen protectors at p800er.com. They also got cases and more..
My wife has a palm; after a year the screen was so scratched we had to exchange it. Fortunatelly she had insurance so it was free.
So, I got a screensaver for my P8. I actually love the viewsonic screen savers because they feel like paper. I did have to cut it to costum fit it to the screen but it took me 15 minutes and now I actually tap on the screen with pens, or keys, or anything. 😊
Brando is the ONLY way to go...
Got mine directly from them, fitted it, had a bloody dog hair under it, pulled it off, WASHED it, put it back on...... Abolutely Awesome.
And the texture feels great too, even cuts down on sun glare.
i used to worry about the screen to ,
but buy a screen protector , and for worst case i bought a new screen for $80,- (incl postage and all) just for spare .
so they not really expensive.
grtx , arnold
I agree with strats. Try getting the brando screen protector. Its the first thing i did for my P800. You wouldnt regret it 😊
Sorry, must have misunderstood you first post. Well for protection against scratches, Brando is definitely the way to go, its the best screen protector. But if you dont have time to buy it yet get any screen protector of any palm device and cut it to the shape of your P800. Thats what I did, but still replace it with brando. no bubbles, easy to apply, gives you a very clear and protected screen in the end.
