I would like to create a new profile on my 5800 which will have the regular phone connections (2G/3G) switched off, but WLAN/WiFi switched on. I know that the "Offline" profile has all connections switched off, and applications such as Skype will ask for permission to use a WLAN connection. But I want to create a profile where WLAN is already switched on, so that applications can use WLAN connection without asking first.
Anyone?
Create new profile with WLAN on but GSM off
As far as I know, can't be accomplished with built-in functionality. Some add-on app might be possible to create, that can turn off the cellular data but leaves WLAN on. I don't know if such apps exits already or not.
