How do I add a folder to my N8 homescreen? I've placed all the mapping apps in one folder, and want to be able to access it from the homescreen. The shortcuts widget doesn't seem to allow this. Can this be done?
Thanks?
Adding folders to homescreen
The folder you have created will be listed as an application when adding to the shortcuts widget. So, add the shortcut widget first then browse for applications. It will be in there.
xcatch22x wrote:The folder you have created will be listed as an application when adding to the shortcuts widget. So, add the shortcut widget first then browse for applications. It will be in there.
I was wondering the same thing myself. thanks for that - works great!
