Install font S60 series
2 replies · 16,134 views · Started 01 February 2012
Hi
I want to install new font into Nokia S60 series (2nd, 3rd). And i know how to do it:
First connect memory card to computer and then copy font into folder Z:/resource/fonts.
But my assumption is my phone did not have a memory card.
So, how can i install the font in a similar way? (I dont want to install the FontRouter software and config FontRouter.ini)
Thanks!
You cannot copy anything to Z:/resource/fonts as it is ROM (Read-Only Memory) and updated only through flashing a new firmware version to the device. You can only read files from the Z-drive (but not from a PC; only from a file manager app on the phone).
You can use C:/resource/fonts (phone memory).
You can also use E:/resource/fonts which can be a secondary mass memory or a memory card.
You can also use F:/resource/fonts which, if the phone has a secondary mass memory, the memory card in that case.
http://darlamack.blogs.com/darlamack/2007/05/changing_fonts_.html
N/A wrote:You cannot copy anything to Z:/resource/fonts as it is ROM (Read-Only Memory) and updated only through flashing a new firmware version to the device. You can only read files from the Z-drive (but not from a PC; only from a file manager app on the phone).
I'm very appriciated. Thank you.
My second question:
I have a phone N70, it uses gdr format font. I want to install Laos Font in my phone. I used Easy GDR Creator to create font from ttf file (OpenType and TrueType), and copied font to C:/System/Fonts folder. My phone had read the font, but it could not display the Lao characters. Latin characters were ok.
Dont know while!
Can someone help me? thanks.
