Hi All,
Spent hours and hours trawling boards tying to find something SO simple, I want a music player on my N8 that I can simply direct to one of my many music folders and tell it to play what's inside.
Eventually paid �1 for Audiowave on NokiaStore which is one of only 2 I could find on there and it does not seem to have ANY file selection ability at all. It just has a massive list of all the audio files on your phone in a tiny window and good luck scrolling down through a thousand or so to find one you want....
The built in media player is incapable of playing music in a folder, forcing you to select it by album/artist (useful if you just put 500 mixed songs in a folder and want to play all of them on shuffle... NOT) and it's literally doing my nut. Something that a windows 95 pc or a 10 year old windows phone could do fine I can't do in 2012. Android and Iphone no problem as any amount of music players are available plus theirs actually work.
I found Folderplay 1.8 but it won't install saying certificate is invalid (if my pc behaved in this manner when I told it to do something I don't know what I'd do!).
Does anyone have any other app suggestions?
On my N86 I installed a great music player which worked like winamp basic and it was called something like gsplayer I think - but I can't find it. It had a symbol like a little green tree and it would play folders just fine - does anyone know what it was?
Help apprecaited - I'm so frustrated by the inability to do basic things on this phone, like last a day on the battery, have bluetooth not flatten it in 2hrs, play music by folder, browse/use data by wifi only when in range, have 3g off unless it's required... I could go on and on.
Greg.
