Is there a way to force either Nokia Software Updater or Nokia Suite to re-flash Belle on to an N8 which has already had the Belle update applied?
I seem to recall this was possible, but perhaps that was only pre-Anna. It seems to me that either NSU or Nokia Suite had an option to apply the update again.
Is Navifirm or something equally as complicated my only hope for reapplying the Belle update to this Nokia N8-00?
Nokia Suite will report that there are no software updates available but if you go into the update screen you'll see a link to reinstall the current (Belle) firmware
matthewrleech wrote:Nokia Suite will report that there are no software updates available but if you go into the update screen you'll see a link to reinstall the current (Belle) firmware
Thank you. I did finally find that reinstall link (it's not easily visible on my laptop's screen). I have reapplied the Belle update and am now working with the phone, to see if it's all there.
