i can't update my playlist because i don't have any accesspoint! would anybody be so kind to post them here? thanks. ))question: can you have an accesspoint not provided by your network?))cheers! ;p
Oplayer v2. accesspoint anyone?
U should be able 2 get access if u use the same access point as ur e-mail mailbox
i don't know how 2 use my e-mailbox. help pls.
If u don't have a mailbox(e-mail) set up on ur phone then u will need 2 look @ ur manual or contact ur network 2 get 1 set up.they will have ur settings(gateway i.P passwords etc.) if u get that set up i can tell u in detail how 2 set things up 4 oplayer v2.02 after that.
Do you have GPRS setup and working, Oplayer needs a gprs connection.
Do you surf WAP sites via GPRS?
Try that as your access point, if it dont work - make a new access point using those setting but then edit the IP to be 0.0.0.0 then try that.
It should work..
Best 😊
Will
It doesn't work, willbrady... I always had d same response.... Request timeout..
Hey try this access the oplayer then select options->settings->access point-> then select an access point that runs off gprs. Preferably an e-mail access point. Or select the oplayer access point. This needs 2 be set 2 the same as your gprs access point. I can give you all the settings 4 orange gprs but i don't know if u can use them if ur on another network.
What's orange's gprs settings?
O.K heres the settings but bear in mind that u need 2 have the gprs enabled first otherwise these settings r useless. O.K here goes. Go 2 tools, settings, connection, access points, options, new, this is the info u need 2 input. Connection name=orange gprs, data bearer=gprs, access point name=orangewap, authentication=normal, gateway i.P=192.168.71.35, homepage=http://orange.Multimedia/, security=off, mode=permanent anything i didn't include isn't 2 b changed. Give it a try & let me know if it works. If so then were in business.
It's not working... =(
What network r u on?
Globe... I should've known better, i'm from the philippines... =(
If u contact ur customer care team there they should be able 2 send u a sim update enabling gprs. The only problem is that they will probably want u 2 subscribe 2 the service so u're going 2 end up paying. U can't use oplayer without gprs. Sorry i can't help but if u get gprs enabled then i will try 2 help if u need it.
I'm using gprs. And it's free. I ask them if they supply settings for email but they don't, they said i should have an isp...
Sorry chris but there's somthing dodgy going on. Turns out i'm now having the same problem eventhough i've been using it since last saturday.
You could try Oplayo support.
** Magic **
chirs, do u know the settings of oplayer on globe??? can u write it donw... thanks! does it also work on RealOne???
