hi
Can nokia e90 read a flash memory like nokia e7
hi
The E90 has built-in Flash memory, as well as support for Micro-SD Flash memory cards.
However, if my memory serves me right, the E7 (E7-00) does not have any kind of a memory card slot.
i mean that i wanna to connect a flash memory throw the usb port & read it like a storage memory
No can do; the E90 does not support USB OTG (on-the-go) and there is no way to add the support to it.
thnx 4 ur time
I have another questions
How can i watch videos from youtube?
Also wanna to capture pics with the internal cam
The last one
Wats the benefit of ctrl key?
Thnx again
You can try http://m.youtube.com but I'm not sure how well it works.
The camera app should allow you to take pictures, and also switch cameras.
The Ctrl key can be used just like on a PC keyboard (e.g., for editing, etc.).
Download and read the E90 User Guide:
http://nds1.nokia.com/phones/files/guides/Nokia_E90-1_Communicator_UG_en.pdf
For that and more E90 guides, see:
thnx alot for ur comment
If I were to buy it, will I experience the same thing coz in my opinion, every nokia E7 will not experience the same thing.
I'm on vacation in the Philippines, and planning to buy a phone here as it's much cheaper than in the US.
No,it's can't
does anyone has the solution for the internet connection on nokia e7. i can connect to wlan but when im going to open web page it says Invalid Server Name.
millions of ppl worldwide own that phone and love it, are u going to go by the review of one person? Phones lag and hang when u dont treat them right.
No, I don't think a Nokia E90 can do it.
Is that true? If I were to buy it, will I experience the same thing coz in my opinion, every nokia E7 will not experience the same thing.
u are comparing a phone with a tablet, so obviously the tablet has the bigger better screen. But the e7 is the device with much better features.
that Nokia E7 looks pretty sweet, but will it still work once I get back to the US? Or what would I have to do to make it work? Any pointers are appreciated!
Hey guys, need some expert advice, I'm planning on buying a phone, but can't really decide whether to buy a Nokia e7 or Samsung Galaxy tab.
nokia E 90 has flash whereas Nokia E 7 is having Dual Led.
I have some useful dictionaries on my N97 which has Symbian S60v5 operating system. The side switch of my N97 broke twice so I decided that it's time to change my cellphone to E7.
For getting your problem solved you should follow the given steps:-
1] u should Restore the original factory settings on your nokia phone.
2]Contact your network operator to check that Internet browsing (data connection) is included in your service contract (SIM card).
3]install the latest software in your nokia phone.
u can try http://www. youtube.com for youtube and a Control key or ctrl is a modifier key which, when pressed in conjunction with another key, will perform a special operation.
thank you
I have configured my company email account in my Nokia E7 and when I press sync it is displaying connection failure.
I think nokia E7 is better than samsung galaxy tab for long term use.
