n86 unlock help
2 replies · 21,583 views · Started 27 March 2012
hello. i just got my hands on a n86 after finally my n95 8gig died. used to know phones and stuff but really aint got a clue anymore. was after a bit of help to get it unlocked as its on t-mobile. if anyone can help i'd really appreciate it. thanks in advance.
Hi, You can unlock your Nokia N86 safer and easier using unlock code. You can get the unlock code for a Nokia N86 from www.wickedunlock.com/nokia-n86/rs11wp9/ at affordable cost.
Here are the steps for unlocking a Nokia N86,
1 - Switch on your Nokia N86 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N86.
3 - Compose #pw+CODE+1#.
4 - The Nokia N86 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N86 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
