Lockscreen Buttons
Requirements:
And all s60v5 mobile
unsigned
Overview:
Lockscreen Buttons allows you to place six apps to lockscreen, apps which you use the most. Select them from Options.
This application allows you to place SIX most frequently used apps to lockscreen and start them without unlocking your phone, straight from lockscreen.
[break]
[break]
more info:-
You can start your favorite apps from lockscreen, without unlocking your phone.
NOTE: Works on both �Slide to Unlock� and �Tap to Unlock�
There is no bar to unlock, it will be added in future release.
This application works on S60v5 ed mobile phones with the latest firmware.
Download Instructions:
After download rename .zip to .sis
Download link:::- Lockscreen Buttons Download
