QLauncher- Widget With 39 Apps Shortcuts.
0 replies · 8,650 views · Started 19 April 2012
QLauncher
Requirements:
and also all s60v5 mobiles -- UNSIGNED
Overview:
QLauncher S60v5 Home Screen Widget With 39 Apps Shortcuts.
QLauncher show 39 applications shortcuts on your s60v5 home screen at your choice.
QLauncher is very easy to use and allows you quick access to your most useable application on one click.
You can change shortcuts by changing UID.
[break]
Download Instructions:
AFTER DOWNLOAD RENAME .zip TO .wgz
Download link here --->>Q LAUNCHER DOWNLOAD
