Widgets-Active Standby Ultra
Requirements:
All symbian s60v5 mobiles --- unsigned
Overview:
View important info of your phone in one screen
The widget�s user interface is cautiously designed so that the user can easily access the various applications/ functions displayed on the mobile screen while using the Active Standby Ultra widget.
On the main screen you can see info about:
Count of unread SMS received
Count of unread MMS received
Count of unread E- Mails received
Count of Missed calls
Status of Bluetooth connection
Number of alarms set
Vibration status
Battery level
[break]
http://www.cellapp.in/index.php/widgets/active-standby-ultraDownload Instructions:
After download rename .zip to .wgz
Downlaod link here ---> Widgets-Active Standby Ultra DOWNLOAD
