C7 Slider Not Sliding So Well
2 replies · 3,293 views · Started 25 April 2012
Hi.
The slider to unlock my C7 doesn't move too smoothly; although strangely, it's clean and clear.
This morning I used a toothpick to lay a drop of fine lube in the hope to smooth thing out, but seems to have zero effect...
Has anyone come across this before?
TIA, Alex
Yes I have the exact same problem too, I'm afraid to do what you did though, hope someone has a solid solution for this.
Keeping my fingers crossed.
Bobak.
Hi, i am c7 owner, lock slider, you can unlock sreen with menu button and download quick lock app, free in app store, so no need to use slider button, i have never used lock slider button,
Hope this helps,
