T-mobile removable
4 replies · 18,748 views · Started 11 May 2012
Hi everyone,
I have an N96 16GB from Nokia. The phone is simlock free. But the most annoying thing is the T-mobile software.
Is there ana chanche to remove safely the T-mobile software and replace it with the complete original software from Nokia?
If so, how is there an howto and where can i find the software, firmware, etc?
Many thanks in advance!!!
The battery life depends on the number of repeatedly charging and discharging, so should try to avoid more charge when the battery power, this will shorten the service life of the battery. Mobile phone off time more than 7 days, should first will phone the battery to completely discharge, enough electricity before use.
Maybe you are talking about to update your phone. I want to tell you that it's very easy process to upgrade phone via internet. First of all connect your phone with the help of PC suite to computer and find update option and update from there directly. So, this process also help you to replce your T-Mobile software.
