when I don't use my satio for some time, the screen goes black/ blank
I want to use it as sort of clock- that when I don't use it, it will show the time (maybe in dim mode? maybe for some time until it goes totally balnk?
is it possible? is there an app for it? how do I do it?
thanks
Very thank you for your message, I think the car is a car support is very good very convenient, compatible with many mobile devices. In the vertical direction, can be in any direction 30 degrees rotation, and the audience is more convenient. Gel type of sucker rod absorption combination, in order to ensure that any plane support. The ball joint ball design, additional friction
http://www.galaxynote2caseshop.com/plastic-360-degree-rotating-universal-car-bracket-28702.htm
