As I recall I deleted this file before already to clear up some space. After the upgrade I had last sunday, the file came back. Well I deleted it with qfilemanager. I just wanted to know if the upgrade was the one who brought it back our was it my restoration after the back up that did it. I restored my latest backup though that supposedly didnt have that demo file also. weird.
Deleting the Demo file
Pare, it's not the answer to your question but I just want to know what is the latest revision of the firmware you got?
R1D
R2C
R1G
R1F04
Upgraded by Semicon, SM branch, Cebu
Thanks a lot kabayan.
Yes, the upgrade brought it back, and now it disapears in the list for "deinstalling software"
[quote="Anonymous"]Yes, the upgrade brought it back, and now it disapears in the list for "deinstalling software"[/quote]
Thats why I had to use qfilemanager to delete it 😊 At least now I know it wasnt just me 😊
Yes, the firmware upgrade will bring it back. While you can use QFILE MANAGER to remove it but i would not recommend it. Just re-install it to the same location from your CD and then uninstall it again from the UNINSTALL list.
COOL ! Thank you!
[quote="chtan"]Yes, the firmware upgrade will bring it back. While you can use QFILE MANAGER to remove it but i would not recommend it. Just re-install it to the same location from your CD and then uninstall it again from the UNINSTALL list.[/quote]
I already deleted it 😞 what have I done? :roll:
