Getting contacts from Android to 808
6 replies · 10,294 views · Started 16 June 2012
Hello!
I've just got my 808 (loving it so far) and want to transfer my contacts from my Nexus S.
Do you have any suggestion how to do this?
Before I had my Nexus S I had a Samsung Wave (Bada) and I THINK I had an app there that can sync many different mobile OS but I can't remember its name.
you can export the contacts list under android (google for instructions)
using PC suite you should be able to import the .vcf file
sync to 808 .. profit
funambol is a great tool. Use the Nokia e7 as regged phone. You can sync over the air, contacts, calender, todo, notes. Even with outlook 2010 to and from your phone devices.
Surely your contacts are in Google/Gmail contacts?
So, just sync your contacts via 808's exchange activesync to m.google.com?
Upload to everdroid.com and then sync to phone on your 808. I use everdroid for calendar, notes and contacts backup.
Al
Can someone with an 808 measure the battery for me?
I need to compare the physical size of BL-4D and BV-4D batteries.
