backup files
4 replies · 1,560 views · Started 03 April 2003
[quote="kikko79"]I made a back up and now I wanto to take a file from the backup file, how to do it?[/quote]
Just change the file extension to .zip and then use WinZip to extract the file you need.
[quote="Bassey"][quote="kikko79"]I made a back up and now I wanto to take a file from the backup file, how to do it?[/quote]
Just change the file extension to .zip and then use WinZip to extract the file you need.[/quote]
Wow is this really possible? So you mean we can edit out backup files, like deleting the ones that you dont want restored? This means the restoration will be quicker?
