Hi, ON my e72, I used to be able to use zip manager to unzip password protected files, but on my e6, this is no longer the case. WHenever I try to unzip these files, I get a message that the file is corrupted. I know that the files aren't damaged, because I can open them on my computer just fine. Any tips would be greatly appreciated. Also, if there are any other unzipping apps I can use that will solve this, that would be great. I can't use java apps because I'm using a screenreader.
Thanks!
Tasha
