Want to have alarm events...
1 replies · 2,202 views · Started 03 April 2003
Hi!
I am trying to make own application which use the phone calendar, so I can set some events and alarms at specific time. I have few problems... I dont know which file the phone is using? Is it schedules.dat or something else? And I dont get working my CActiveScheduler or it gives error that there is active scheduler allready? How should I correct this?
Btw. I have used those examples from SDK
Hello from Turkey,
ı want to activate an alarm when an event occurs. Not a clock or agenda alarm, it will play when some cases occur. example when a menu item clicked.
its realy difficult to understand symbian sdk, there no enough documentation and samples.
if you have any sample code for alarm please help me...
Thanks...
