Handy Safe Pro (NOT) on Nokia 808 Pureview!
2 replies · 5,997 views · Started 20 July 2012
Oh no! I have been using Handy Safe Pro (confidential information database) and its desktop sync on all my phones since the N70 was first released. I downloaded and tested it on my 808 yesterday, and as it seemed to work OK, I paid for a licence for it on the 808. However, Handy Safe Pro will not allow me to enter the Product Key. As soon as I select the Register option the screen flashes the entry dialogue, goes blank, and then the application quits. Even worse, I put in a support request and they tell me that there are no plans to do any further work on it.
So, has anyone figured out a way to get past this problem? The app does work on the 808 but, at the moment, only for another 13 days .
Or can you suggest an alternative app which you know does work fully on the 808?
her is the answer, little late, though.
I had the very same problem and also wrote to Handy Safe support. Surprisingly, they provided answer which worked.
Go to manual activation page:
http://regserver.epocware.com/activation
Enter serial, IMEI and IMSI (under telephone info in Handy Safe first screen) and select "By license file". Enter captcha and press Activate. You will receive .sis file with your license file, which you install on your 808 as normal app via Nokia Suite. Start Handy Safe and it is activated.
Hope that helps.
