can the videos i have made on my phone send to my pc? im not sure how to do this i have bluetooth and can do pretty much everything else. thanx :robot:
videos to pc
yes you can send
first of all install a file manager to your phone. (fexplorer is free)
then go to the folder that videos are saved (if you are using the latest nokia video recorder, videos are saved under c:\nokia\videos)
then press options, go onto send, you will see the option Via bluetooth. hit the button 😉
i tryed but it says the max number of bluetooth connections already in use 😞
Change the video files (.3gp or something) to .jpg and transfer them with
the image transfer from pc suite.
It works for me.
ok i did that...but it wont let me change the file type to mpg when ive got it on my pc...any ideas? :cry:
Try the following steps, it should solve your problems:
1- You can't transfer your videos when mRouterRuntime.exe is running or connected to your phone. Click on the icon in the system tray, chose CONFIG and disconnect the COM connected to your phone.
2- Select the video file and SEND > BLUETOOTH > "your_desktop_bluetooth_device"
If this doesn't work:
1- Install FileManager in yout PC, with mRouterRuntime.exe connected to your phone, run FileManager
2- Browse your phone and COPY the videos
3- Select a folder in your PC and PASTE them
Any way, DO NOT rename them to MPG, they aren't. Instead download NOKIA VIDEO PLAYER from www.nokia.com/phones/3650 <-- search in the software section
and ENJOY!!!!
