Fastxt removal
3 replies · 1,652 views · Started 03 April 2003
How do I remove Fastxt from my phone - I have tried all the usual to no avail 😮(
Is the app half installed and half not (stuck) then send the sis file to your phone, install it, and hopefully it will appear back on the manager so you can uninstall it again. (that's what i did when a certain app got stuck)
Hope it helps! You can always back up your phone and contacts and then format if you're really annoyed by that app.
If you mean that stupid install file that has to be installed first to download the main app, but doesnt show up in manager. Use a file explorer, browse to C:Systems/Apps and the name of the folder which im not sure of but its obvious which one it is when you see it. Delete the folder and the shoetcut icon on the phones menu screen will also disapear. Pain in the ass i know but its the only way i could get rid of it.
Stezos
