Nokia 5800 - White menu button issue
0 replies · 23,664 views · Started 24 October 2012
Dear Sirs,
I have purchased a Nokia 5800 from e-bay and the whte button that lets you into the menu system is not working or showing any signs that i am pressing it.
I have tried replacing the LCD frame that had new circuit bits at the bottom, but no luck, I really do hope it is not PWB.
The RED and GREEN buttons work just fine.
Need some support and guidence from you the experts, PLEASE.;
Kind regards, Jonathan
