G2 Screen Proctector
4 replies · 1,830 views · Started 04 April 2003
I've search thru this forum and found nothing about this.
i'm just curios, has anyone try it? comments?
http://www.the-gadgeteer.com/g2-screen-protector-review.html
http://www.pdascreenprotectors.com/ultimate.htm
http://www.dgotech.com/morepalm/reviews/g2scrprotector/revg2.html
http://www.ppcshowcase.com/hardware/G2_screen_protectors.htm
http://www.oozp.org/rhpcg2.htm
http://www.geek.com/news/geeknews/2003Mar/bpd20030305018811.htm
p/s: i'm not working/representing them...
wonder if they has a customized product for P800?
I have been using G2's on different PDAs and love the screen resolution while using the G2. They are crystal clear! I have been using a Brando screenprotector for my P800 for about 4 weeks...then tonight, went thru my "junk" and saw a spare G2 that I have for my Tunsten T. (a single order contains 2 G2s). So, I decided to cut it and then placed it on my P800...the protector is so clear that you can't even tell if one is installed or not. However, IT IS A PAIN TO INSTALL (I have much experience with it since I have used it on every PDA I owned having went thru about 6 PDAs in about 3 years because I am one of those who "just got to have the latest gadget 😊
So, there are advantages and disadvantages to using either the Brando or G2...
Brando: ADVANTAGE: easy to install, durable, protector can be cleaned and placed back on the P800 quite easily...DISADVANTAGE: cuts back on screen resolution a bit.
G2: ADVANTAGE: crystal clear, so clear that people can't tell that you have a screen protector, very durable (the one I had on my tungsten has been there for more than 6 months...no visible scratches seen on the protector...can be cleaned too but if not done with care, you can "destroy" the G2...DISADVANTAGE: a big pain to install (but really worth it if installed well).
[quote="Guest"]I have been using G2's on different PDAs and love the screen resolution while using the G2. They are crystal clear! I have been using a Brando screenprotector for my P800 for about 4 weeks...then tonight, went thru my "junk" and saw a spare G2 that I have for my Tunsten T. (a single order contains 2 G2s). So, I decided to cut it and then placed it on my P800...the protector is so clear that you can't even tell if one is installed or not. However, IT IS A PAIN TO INSTALL (I have much experience with it since I have used it on every PDA I owned having went thru about 6 PDAs in about 3 years because I am one of those who "just got to have the latest gadget 😊
G2: ADVANTAGE: crystal clear, so clear that people can't tell that you have a screen protector, very durable (the one I had on my tungsten has been there for more than 6 months...no visible scratches seen on the protector...can be cleaned too but if not done with care, you can "destroy" the G2...DISADVANTAGE: a big pain to install (but really worth it if installed well).[/quote]
What do you mean by being hard to install? Bubble problems?
Hard to install because you have to protector is larger than the screen, you have to slip it into the sides of the P800. It is non-adhesive and is held in place by being sandwiched between screen and the sides. It is very tight so it doesn't "wiggle" around. One other thing, since it is "crystal clear", it doesn't cut down on glare.
