Charging problem in my mobile
plz tell shre you info what problem in my mobile...
Charging...
Meaning that when i charge the rechargeable lithium-ion battery for a Mp3 or IPOD, and that the battery is still dead after 8 hours of charging.
the best option is to change the battery once and observe.
Can i leave the computer on standby mode while charging my phone?
No i can't use the wall outlet because my phone can't charge with the wall outlet.
It'll only charge on the computer.
yes, sure you can leave your computer on stand-by mode.
May be your charging point in your phone is defected, take it to the nearest service centre and see.
yes You can leave your phone on standby mode while charging.
may be your software is out of date. check it once and update it.
The USB cable is also the data download cable,once you connect your phone with your laptop by the USB cable,the phone is under charging condition.
yes and you can even put your phone on standby mode.
I have a battery charger for a remote controlled tank and on the charger it says charging-slow flash and trickle charging-fast flash.
Shelleycarlett wrote:Meaning that when i charge the rechargeable lithium-ion battery for a Mp3 or IPOD, and that the battery is still dead after 8 hours of charging.
I think the phone's life is towards the end. Contact the service provider or manufacturer.
