Setting up IM
6 replies · 2,107 views · Started 04 April 2003
IM+ ? see the attachment... works fine
crap... to big file to attach... you just go to option/services/*aol/icq/msn*/preferences and fill in your login and password... port should be filled in already. if not icq = 5190 , msn 1863, AOL 5190... attempts can be set at "2" . Then press "done". and it�s done! 😉 Just connect...
i have done wat you sayd and than my phone says no connection available, how come???:s
Are you using a GPRS internet access point or just WAP? I imagine you need to use an internet AP.
i am using gprs and im+ will not connect it says no connection availeble
the question is - gprs what?
WAP or INTERNET ?
On T-mobile it works with both, but some networks you will find apps like these will only work with GPRS INTERNET.
Which, again on some networks only, can be acheived by creating a NEW access point and having 0.0.0.0 set as the IP address.
Will
