MiniGPS Question
1 replies · 1,658 views · Started 04 April 2003
I'm trying to use the trial version of MiniGPS but I'm having a problem and would like to know if anyone else has had this and fixed it (I have sent an e-mail to PsiLOC but they have not been able to replicate the issue)
Anyway, when I set up events and the event takes place (for example, if I want a ringtone to go off when I enter a cell), the application flags up an error saying that it is out of memory and I should shut down applications.
I have more than a Mb of storage space and MiniGPS is the only application running.
Any ideas?
I tried deleting the database from when I installed the beta version. I'm kind of worried that there are more files in there from the beta version influencing.
Any ideas?
