list of compatible bluetooth adapters for 3650
10 replies · 2,844 views · Started 04 April 2003
well i've seen a list of bluetooth dongles at 7650 forums, but they were only a few...
well does anyone tried the epox bt-dg02 ?
I'm using CONCEPTRONIC CBTU....
and NOW it works fine........
it is from TULIP Computers Netherlands
I use a 3-com one at work, they are more expensive but it installed and ran straight out the box and did not need any tweeking. Even for sending images from the one to the PC.
I have a Belikin on for my laptop and that was slightly problematic.
Best 😊
Wll
I have a Trust BT120 Bluetooth adapter. It works OK, once I get mRouter to connect, hehe. I have to try to connect the Bluetooth Serial Port a couple of times before mRouter "wakes up". After that it works fine.
I've got a mitsumi one but despite following guides on this forum I *cannot* get the thing working with mRouter :'( It works for sending/receiving files tho.
hi,
i use a sitcom BT stick. it works fine. a couple of searching and it will go straight.
cya amigappc
I'm using a Waverider bluetooth dongle and it's a bloody nightmare 😞
It took hours to install and is very, very tempremental :agrue:
