http://www.psiloc.com/nokia/eng/irremoteS60/index.html
For NOKIA 7650/3650
http://www.psiloc.com/nokia/eng/irremote7/index.html
For P800
Infrared Remote Control for SE P800
Supported remotes:
Sony
Sony Alt
Philips
Philips Alt
Panasonic
Panasonic Alt
Technics
Aiwa
Blaupunkt
Daewoo
GoldStar
Grundig
Grundig Alt
JVC
Loewe
Samsung
Samsung Alt
SEG
Sharp
TechniSat
Toshiba
Universum
Akai
Denon
Hitachi
Hitachi Alt
Nec
Pioneer
Sanyo
Thomson
Thomson Alt
LifeView
P800 ap is still in the finalization process, but its been like that for almost a month and a half now 😞
and your link is broken! i get an error 404
[quote="Muzikfreakah"]P800 ap is still in the finalization process, but its been like that for almost a month and a half now 😞[/quote]
Yes indeed, this is old news, I had seen it sometime ago to. Nevertheless, I REALLY want that app...
Whoah. They have updated their site. They are saying that their first beta version will be released this week (from 7 april to 14 april). And because the IR port is on the left side, they made a horizontal version!!!
http://www.psiloc.com/?id=prod&nrp=85
I thought i heard the beta version wasn't avalaible anymore, has anyone been lucky enough to test it? how does it work and from how far?
[quote="Delta737"]Whoah. They have updated their site. They are saying that their first beta version will be released this week (from 7 april to 14 april). And because the IR port is on the left side, they made a horizontal version!!!
http://www.psiloc.com/?id=prod&nrp=85[/quote]
mrgadget is right, they said the beta is not avlble anymore and that it should be coming out soon already.. tsk tsk.. I would really want this ap too! 😊
Hello, I've got a Beta version.
Mod Edit: Beta versions are not for general distribution. Do not post attachements of beta versions here. Link to them.
[quote="Tsutsi"]Hello, I've got a Beta version.[/quote]
Nice one.... downloaded it.... try later.... still @ work.
Mod Edit: Beta versions are not for general distribution. Do not post attachements of beta versions here. Link to them.[/quote]
Cool it works!!! 😊 Thanks! one irritating problem though, after I installed it all my applications went into the unfiled folder 😞 Had to categorize everything accordingly again. 😊
Tested it with a sony tv and it works. Have yet to test it on other devices 😊
i used the IRremote on my p800 & it seemed to work on my sony TV but not on my JVC & other indian brands.
it works from a distance of about max 2-3 metres.
, not more...& the sight of line has to be kept.....so that means not much of an angle.
with my sony TV...channel up & volume up works & power also. cant get the channel down & volume down to work.
I only hope the final version has a LEARNING FUNCTION... is that even possible? should be...??I wish it does, caus i have one remote for my TV, DVD, AMP, Curtains, FAN & A/C
Also thank god they changing the position as the IR is not up in the front of the phone.
HyPeR
Well, you don't have to post it or anything, but I got a question. How on earth did you get that beta???
maybe this is the beta version
http//www.psiloc.com/?id=prod&nrp=84
Yes it's written in my first post ...
[quote="dummian"]maybe this is the beta version
http://www.psiloc.com/?id=prod&nrp=84[/quote]
I believe this is the Series 60 version. Or not???
I have also "tried" a version of the beta, and couldn't get it to work, again with a Sony television.
Do you guys start ir before you load it? I tried that and it moans, but I can't see a signal coming out of the ir socket when i use it....
Roll on final... something i will happily pay for.
