Can P800 browse with the PC's connection using Infrarec, Bluetooth or Cable?
Browsing pn P800 using PC's conection
Yes it can, if you have the docking cradle that is used to sync the p800 with your PC. Put your p800 in the docking cradle; check it is connected (phone icon in system tray); dial-up on your PC to the internet; open up opera web browser and then it should automatically pick up on the PC connection with no further setup required.
[quote="|3|_uEtOoTh�"]Can P800 browse with the PC's connection using Infrarec, Bluetooth or Cable?[/quote]
Cable is the same as the docking cradle, its a usb connection.
the opera browser picks up on the infrared and bluetooth connection aswell.
