headset trick
4 replies · 2,309 views · Started 05 April 2003
Some days ago i read a post from some guy that wanted to listen to mp3's via headset, but the sound turned down, and then i found out that if you press the red button so you will get out of mp3go, but the music is still playing, then you go into tool, settings, accessory, and a last choose loopset as accessory in use, and the sound will be loud again... Hope you understand.
[quote="KAX"]Some days ago i read a post from some guy that wanted to listen to mp3's via headset, but the sound turned down, and then i found out that if you press the red button so you will get out of mp3go, but the music is still playing, then you go into tool, settings, accessory, and a last choose loopset as accessory in use, and the sound will be loud again... Hope you understand.[/quote]
I understood but it didn't work... sound still s**ks thru my BT headset...
