I play mp3 on my phone and I connect the headset the sound comes from the headset and also from the speakers????
why is that...is there anyway i can stop the sound to come out from the speakers while playing mp3??
MP3+headset but sound from speakers also?WHY!!
anyone?? :cry:
Someone suggested that you switch out of Mp3Go while playing an mp3, and go into Tools | Settings | Accessory, and choose Loopset as accessory in use.. really odd, but apparantly that should work.
tried that It only made alittle more sound come from the headset....but sound was still coming from the speakers.. 😮ops:
I have the same problem.
But i think its a software problem. While listening to .wav files from the normal recording-application everything comes through the headset.
If u try to put the plug of the headset in very slowly and press it a little bit to any direction while playing mp3s it sometimes works...
Try a few times and you will have luck... 😃
ok Ill try that.....thanks 😃
